When i connect to a vpn connection my wifi stops working
tumzithesavage
Post by tumzithesavage » Wed Oct 23, 2019 2:08 pm
i have a hp x360 13, i have tried resetting, my wifi settings, i deleted the vpn and got it again, i've deleted and rejoined the network, and it still didn't work, please help me find some solutions, windows trouble shooter says" Your computer seems to be correctly configured, but the device or resource(Dns server) is not responding"
Last edited by tumzithesavage on Thu Oct 24, 2019 4:06 pm, edited 2 times in total.
ozone
Re: When i connect to a vpn connection my wifi stops working
Post by ozone » Wed Oct 23, 2019 6:21 pm
Hahahaha Sky59, do want to know how it smells too???
@tumzithesavage : If you really want a serious response, you should at least supply a proper description of the problem and what you already tried to fix it. With that info, and if somebody on this forum knows how to fix it, he/she will be happy to let you know how.
tumzithesavage
Post by tumzithesavage » Wed Oct 23, 2019 6:29 pm
just did that, thanks for your help!
ozone
Post by ozone » Wed Oct 23, 2019 7:18 pm
Still fishing here...
I assume you try to connect to a VPN with your laptop (running windows?) while on wifi right?
And then, once you are connected to your vpn (successfully?), you noticed your wifi isn't used to traffic data to internet or wherever?
But your VPN link is "up".
Am I getting warmer?
tumzithesavage
Post by tumzithesavage » Thu Oct 24, 2019 2:22 pm
yes, my vpn is connected and i dont get any internet accsess from my wifi
MyronSz
Post by MyronSz » Thu Oct 24, 2019 7:21 pm
Is the computer hosting SoftEther server Linux or Windows? Is the bridge a physical network adapter of if Linux, a TAP device? If a TAP device how have you got SecureNAT set-up and how?
Don't post any sensitive information in your reply.
