Error (Error Code 9): User authentication failed.
EckyBrazzz
Post by EckyBrazzz » Fri Nov 01, 2019 10:05 pm
Great news, installed the VPN on CENTOS 7
https://www.softether.org/4-docs/1-manual/7._Installing_SoftEther_VPN_Server/7.3_Install_on_Linux_and_Initial_Configurations
cd /tmp/
wget https://github.com/SoftEtherVPN/SoftEtherVPN_Stable/releases/download/v4.29-9680-rtm/softether-vpnserver-v4.29-9680-rtm-2019.02.28-linux-x64-64bit.tar.gz
tar xzvf softether-vpnserver-v4.29-9680-rtm-2019.02.28-linux-x64-64bit.tar.gz
cd vpnserver
cp -va /tmp/vpnserver/ /
cd vpnserver/
Created init.d script
#!/bin/sh
# chkconfig: 2345 99 01
# description: SoftEther VPN Server
DAEMON=/usr/local/vpnserver/vpnserver
LOCK=/var/lock/subsys/vpnserver
test -x $DAEMON || exit 0
case "$1" in
start)
$DAEMON start
touch $LOCK
stop)
$DAEMON stop
rm $LOCK
restart)
$DAEMON stop
sleep 3
$DAEMON start
echo "Usage: $0 {start|stop|restart}"
exit 1
esac
exit 0
Works server starts stop & restart
When I check if it listens to a port
netstat -ltnp | grep -w ':1194'
tcp6       0      0 :::1194                 :::*                    LISTEN      4918/vpnserver
Great works.
Create user
Create certificate for user
Create certificate on server
Try to log in on all different ways, password, certificate, no password, but get the message Error (Error Code 9): User authentication failed.
How to solve this?
Thanks for any advice!
EckyBrazzz
Re: Error (Error Code 9): User authentication failed.
Post by EckyBrazzz » Sat Nov 02, 2019 5:58 am
Resolved, that CSF issue is the cause so need fix for that.
particlefeever
Post by particlefeever » Mon Jun 06, 2022 5:46 pm
Hi! I have the same problem, but didn't understand how did you solve your. What is CSF issue?
Tokkiedekip
Post by Tokkiedekip » Fri Jul 22, 2022 6:28 pm
I have the same issue. Did you fixed it?
admin5547
Post by admin5547 » Mon Sep 19, 2022 4:32 pm
I am having the same issue , 2019 Standard Server & windows 10 client. Can you advise on when I can look ?
Post by solo » Mon Sep 19, 2022 11:43 pm
FYI
CSF = ConfigServer Security & Firewall
"A Stateful Packet Inspection (SPI) firewall, Login/Intrusion Detection and Security application for Linux servers."
