SoftEther Client Manager Not Connecting
praveenpushkin
Post by praveenpushkin » Tue Nov 05, 2019 1:30 pm
I installed SoftEther Client Manager as per the Instructions,
In the New VPN Connection Properties Window I enter the parameters
1) Name Type : MyHostVPN
2) Host Name : I don't know (the instruction tells it is in email package, I didn't get an email or anything) I just download from Internet.
3) Port Name : 443
4) Virtual Hub Name Dropdown : Nothing happened (I typed myhostvpn)
5) Authentication Type : Select adius or NT Domain Authentication
6) Username: MyHostVPN username. (I typed)
7) Password: MyHostVPN password. (I typed)
Then Click OK.
Then, Click Connect.
But Error connection window coming. I tried several times, I don't know how to manage these thing.
Please give me a solution.
Thanks & Regards,
Praveen Pushkin
petenunez
Re: SoftEther Client Manager Not Connecting
Post by petenunez » Sat Nov 09, 2019 2:20 am
I also have the same problem, hope to get help
sky59
Post by sky59 » Sat Nov 09, 2019 12:34 pm
Do you have a server!?
Who has configured it?
Do you know ip address of the server?
dinesh
Post by dinesh » Mon Nov 25, 2019 12:44 pm
I'm getting this error please suggest a resolution for it.
Error:
several VPN Servers on same IP address. you can specify the destination server's private IP or hostname concretely such as "Global ip address or host name/192.168.x.x". Or if a
NAT is used on the server's side, configure the NAT to open, relay or transfer appropriate por
sky59
Post by sky59 » Mon Nov 25, 2019 1:37 pm
you have conflict in network, who declared IP addresses?
dinesh
Post by dinesh » Mon Nov 25, 2019 2:37 pm
ISP PROVIDER give me this static ip
Please tel me how to slow this problem
Thanks
Dinesh
sky59
Post by sky59 » Mon Nov 25, 2019 2:49 pm
how you know if it is public ip? may be isp connects more people to the same ip, ask isp
dinesh
Post by dinesh » Mon Nov 25, 2019 5:18 pm
This is static ip I take from isp
sky59
Post by sky59 » Mon Nov 25, 2019 5:34 pm
You need PUBLIC IP and nobody else is on the same ip
sky59
Post by sky59 » Tue Nov 26, 2019 2:31 pm
What situation?
