I have Softether server that is running on windows 10.
I'm using softether client to connect from other windows computers to the server without any problems.
The problem is that when i'm trying to configure a vpn connection on Android or Ios, the connections are fails.
the provided info in Softether website didn't helped me,
any suggestions?
Thanks
Can't connect to a Softether server from android or ios
terkazarian
sky59
Re: Can't connect to a Softether server from android or ios
Use SE client also on amdroid
Bbs9975
Try using openvpn android to connect to windows 10 server softether
Use securenat
Use securenat
xsystema
Did you open UDP ports 500 & 4500 in your router firewall?
Bbs9975
gincapurro
asil
try using OpenVPN and import its config file from the server with the certification
