Remote Access VPN Server Greyed Out.
kmabe12
I'm trying to use my home network as a VPN server, but it seems SoftEther has a problem or I'm doing something wrong. I'll be grateful for any help. My problem is shown in the image below. The remote access side is greyed out. I'm using windows 10(The latest update), an i5 3470, and 8GB ram.
Re: Remote Access VPN Server Greyed Out.
You should have installed VPN Bridge instead of VPN Server.
Uninstall it and reinstall VPN Server.
rwebb616
Actually just the opposite... you need to install VPN Server and not bridge.. .if the remote access side is dimmed that means you installed the bridge component.You should have installed VPN Bridge instead of VPN Server.
Rich
