TCP vs UDP
boax
TCP vs UDP
Post by boax » Fri Jan 10, 2020 5:12 pm
TCP vs UDP: What is the difference for a VPN ?
Thank you
Re: TCP vs UDP
Post by cedar » Tue Jan 14, 2020 10:26 am
There is no significant difference for VPN users.
TCP is suitable for connecting to an environment where port forwarding can be set on the router on the VPN server side.
If you use UDP, there is a chance that an administrator who does not know the router settings can set up a VPN server, but the connection may be unstable depending on the compatibility with the router.
In UDP, packet loss is ignored in the VPN layer, which also has the effect of preventing delay deterioration in environments where packet loss occurs frequently.
Either way, VPN will not be practical in environments with lots of packet loss.
boax
Re: TCP vs UDP
Post by boax » Tue Feb 04, 2020 11:04 am
thank you !!!
