Watch out for the impact of IPv6 on VPNs
Nt_setvwy
In the process of using the VPN, I found that when the IPv6 option of the network card is turned on, the traffic becomes extremely unstable, so I turned off the IPv6 option and it is completely normal. This is my experience in long-term exploration. Help, but also hope to attract the attention of developers, IPv6 protocol has indeed affected our VPN, thank you
fenice
Re: Watch out for the impact of IPv6 on VPNs
That's not my experience. All my machines have IPv6 enabled and none of them show any problems when accessed via a VPN remotely and none of them have any problems accessing the internet etc. over a VPN.
You'd be far better describing the problems you're having than just saying 'it doesn't work'. Which distribution(s) are you using, what sort of problems, are you behind a NAT router, which version of SofetherVPN etc., etc. The more detailed your description the more likely you are to get help.
Nt_setvwy
Because I come from a region where information is strictly controlled, we are troubleshooting the root cause one by one. Starting with the analysis of the network environment, it is possible to delist our Huawei equipment.
