I've just discovered Softether and before going on working on I would like to check if the following architecture can be done :
- SoftEther VPN Server on Windows 2016 Server (Azure VM)
- Remote network connected over plain IPSEC VPN (Firewall Sonicwall)
Main thoughts:
- Promiscuous mode not supported on Azure, so may be SoftEther not working ?
- SoftEther on Windows 2016 package offered on Azure marketplace , so seems possible to install however ?
- SoftEther Azure VPN Relay : useful in my case ?
Thank you for your hints.
PM.
SoftEther VPN server on Azure Windows VM, possible ?
pm92
centeredki69
Re: SoftEther VPN server on Azure Windows VM, possible ?
- SoftEther VPN Server on Windows 2016 Server (Azure VM) ***** This will work fine
- Remote network connected over plain IPSEC VPN (Firewall Sonicwall) ****** This should work if you enable the IPSEC option on the "SE server"
- Promiscuous mode not supported on Azure, so may be SoftEther not working ? ***** You will need to enable and use the "SecureNAT" feature and NOT" local bridge"
- SoftEther on Windows 2016 package offered on Azure marketplace , so seems possible to install however ? ***** I install from the Official SE Website
- SoftEther Azure VPN Relay : useful in my case ? **** SE Azure is only need if you are restricted from opening/forwarding firewall ports. It is called "AzureVPN" because SoftEther choose to host their free relay services on "MS Azure servers" when they created the software. Not a requirement but can be used. https://www.softether.org/4-docs/2-howt ... .VPN_Azure
pm92
Thank you for these details.
I've just given a try to SoftEther on Windows 2016.
It seems that plain IPSEC (IKEv2 IPSEC site to site tunnel with Sonicwall) is not really supported, rather than L2TP/IPSEC.
I managed to get IPSEC phase 1 going through, but no more.
Configuration seems to insist on having username/password to authenticate connection, but an IPSEC
tunnel is based on other parameters to identify the client side (IKE ID, IP, authentication protocols,...).
Logging is also a bit limited to be able to debug what's going on.
If you (or someone else) have some hints, they are welcomed.
Thank you.
PM.
Thank you.
PM.
pm92
After some thoughts and tries, I don't think this IPSEC configuration would ever work between Sonicwall and SE.
I end up setting up a Linux VM on Azure side, with strongswan installed.
Worked immediatly...
PM.
PM.
