Softether on Windows 10 with ARM64 processor
coldice2007
Post by coldice2007 » Wed Mar 11, 2020 2:27 pm
I have a new Surface Pro X with SIZE=150 Windows 10 and SIZE=150 ARM64 processor. Is there a way to get a version of Softether for this system?
The X86 version works at least in the X86 emulator, but the network driver that is created cannot be installed.
artioni81
Re: Softether on Windows 10 with ARM64 processor
Post by artioni81 » Sun Mar 15, 2020 1:20 pm
Are you looking for the client or the server part of softether?
coldice2007
Post by coldice2007 » Tue Mar 17, 2020 10:02 pm
Only for the Client.
temcocontrols3
Post by temcocontrols3 » Sat Oct 15, 2022 8:24 pm
I also have this problem......cannot install the virtual adapter
wangyp12138
Post by wangyp12138 » Thu Dec 29, 2022 2:51 am
I also have this problem......cannot install the virtual adapter,,, anybody can solve this problem
Post by solo » Thu Dec 29, 2022 3:44 am
No
Supported CPUs
Windows
Intel x86 (32bit), Intel x64 (64bit)
https://www.softether.org/3-spec#Supported_CPUs
christopher.bonitz
Post by christopher.bonitz » Sun Jul 07, 2024 7:35 pm
Would be cool if we could have Arm64 support, I think the problem will rise.
I just acquired the new Surface Copilot from Microsoft, only two programs that lack support is google workspace and softether (in my tech stack).
Two weeks ago google had 81 "complains" on the lack of this support.
Today that number is 192, so there is definitely a push happening on this CPU architecture
(I see its supported in Linux, may actually abandon Windows to resolve this requirement).
kibervandor
Post by kibervandor » Tue Aug 20, 2024 10:34 pm
HI!
I just got my arm based laptop and have tons of clients w softether already set up, so for me it is a must.
My first idea is to set the server to permit ipsec connections and any "regular", windows built in connection, so you can connect to your softether server w/o the client.
Will post updates.
update: yes, it works!
image url https://ibb.co/0y0nHy4
In windows, you have to create a new VPN with vpn type L2TP/IPsec w pre-shared key.
During setup, use the same one as you set in the server config.
When done, you need to adjust the advanced config in "More VPN props"
https://ibb.co/P66cmnk
so not the VPN would be the default route.
Gabor
