Hi All,
I've got a SE Server running behind a NAT firewall, using SecureNAT (no bridge) and while I'm able to connect to it fine, I can never get more than 2 TCP connections, not matter what I set it to in the client.
Is there somewhere I should be "allowing" multiple TCP connections per client on the Server? I can't find any setting for this.
Thanks
Unable to get more than 2 TCP connections
Re: Unable to get more than 2 TCP connections
there was the same problem, we decided to open it on ports 992, 5555 and 8888 the firewall where the softether are installed
Server Side Hub Config
Client side SEVPNClient config (change that number)
