Hi there.
I have 2 questions about SoftEther5 client.
Is it possible to use it to connect to L2TP+IPSEC VPN server?
Is yes can anyone please provide me with step-by-step instruction how to configure it on OpenWRT?
We have 2 routers, first one is Microtik which acts like L2TP+IPSEC server and second is OpenWRT router which should act like client. First one is configured and we have a lot of clients like Windows, Linux, Android, other Microtiks. But problem is in OpenWRT...
Thanks in advance.
SoftEther client for L2TP+IPSEC VPN
centeredki69
Re: SoftEther client for L2TP+IPSEC VPN
The SoftEther client is used only for connecting to a Softether server using the Ethernet Over HTTPS-SSL VPN protocol.
wildman
ok, thank you.
I've seen couple times that SoftEther client is capable to handle IPsec+L2TP so I decided to ask and clarify.
centeredki69
The SE server is able to function as a L2tp/IPsec server.
