Hi Folks,
When I run command:
>> sudo ./vpnclient start
I get the message:
SoftEther VPN Client service has been started.
But then if I immediately run:
./vpnclient stop
I get:
SoftEther VPN Client service has not yet been started.
I am confused by this behavior and wonder if this has something to do with failing to connect to my remote server.
Does anyone know whats going on?
VPN start/stop confusion
jfmachado
Re: VPN start/stop confusion
I saw this once.
first of all, kill all the vpnserver processes.
Then, start the server. Take a look at the log output for the server (they're all inside vpnserver folder). If something's wrong, it will be there.
Take a look at the listeners at the configuration file. If you have another service running in one of this ports (for example, 443), the service may misbehave.
Regards,
Fernando
Regards,
Fernando
