Hi i create a VPN, and after testing i have an issue.
I create 3 differents users, with differents passwords.
The problem i have for example if the User 1 is connected, if it is to connect from another device, it leaves it without problems.
I want to either disconnect it from the previous device, or a legend will appear on the new device that this user is in use.
Thanks
1 User 1 Connection
centeredki69
Re: 1 User 1 Connection
Manage User > Edit > Check security policies > Security Policy > Maximum number of multiple logins > check define policy > set to "1"
