Is there a way to force TLS 1.3?
drkrool
Post by drkrool » Mon May 25, 2020 4:41 am
I've changed the bool TLS_Disable_1_3 to false, every other for older protocols to true to only keep 1.3 activated but when I connect from a windows 10 client to a fedora 31 server, It still accepts tls 1.2 and won't use tls 1.3
Anybody got TLS 1.3 working? I think it used to work but can't figure out yet what changed.
Thank you
