hi, hv setup Softether(SE) on Ubuntu and everything is running fine. Then found out ppl could use nmap and find out our SE's ddns. How could we prevent this? here is the output of the namp scan and it is clearly showing the ddns to the world-
Not shown: 65533 filtered ports
PORT    STATE SERVICE
22/tcp  open  ssh
443/tcp open  https
|_http-title: 403 Forbidden
| ssl-cert: Subject: commonName=vpn364794443.softether.net/organizationName=vpn364794443.softether.net/countryName=US
| Not valid before: 2020-05-31T14:26:40
|_Not valid after:  2037-12-31T14:26:40
|_sstp-discover: SSTP is supported.
						Softether DDNS exposed to the world?
				ziddey
Re: Softether DDNS exposed to the world?
you're free to generate your own server certificate... it's under "encryption and network" in the server manager
