openvpn for multiple hubs on the same server
Argest
Post by Argest » Sun Jul 05, 2020 9:32 am
I have two hubs in Local bridge mode. can I activate openvpn and L2TP for two hubs at once? I need to be able to choose which hub to connect to hub1 or hub2 over the Openvpn Protocol. In a standard Openvpn server, you can run multiple servers with different ip ranges on different ports. My hubs also have different ip ranges, but I can only connect to one main hub over the openvpn Protocol.
dzord
Re: openvpn for multiple hubs on the same server
Post by dzord » Mon Jul 06, 2020 7:34 pm
Yes, you can.
You must specify on your client username with hub name: steve@hub1 or bill@hub2
RiseTheFlag
Post by RiseTheFlag » Wed Jul 27, 2022 12:20 pm
dzord wrote: ↑
Yes, you can.
Thank you? it works for me too. But what about if i use cert auth not usernames?
Post by solo » Thu Jul 28, 2022 12:36 am
RiseTheFlag wrote: ↑
Since SE-OVPN does not support cert auth, how can you use it?
