Migrate Server from Windows to Linux
HalfNote5
Post by HalfNote5 » Sun Jul 12, 2020 11:53 am
Hello everyone!
I have a SoftEther server I would like to migrate from a Windows 7 machine to a Linux-based machine, in its entirety.
I was wondering if there is an easy way to do this by moving a config file of some sort?
Which file(s) would I move and where would I place them?
Thanks very much!
(EDIT: SoftEither is already installed on the Linux machine. I'm having less than stellar luck configuring it manually, and migrating seems like the easier option if it's possible.)
drkrool
Re: Migrate Server from Windows to Linux
Post by drkrool » Fri Jul 31, 2020 1:50 am
Yes, use the vpn manager GUI, connect to the server, go to edit config and export the file
Now connect to the new linux server and import that file. Everything will be ported
It's maybe doable using vpncmd (command line) but you'll have to figure this out as I've never done it this way. Anyway if you use windows, use the GUI for that
