Setting up VPN Gate not found
LonnieTC
Post by LonnieTC » Sun Sep 06, 2020 7:04 pm
Hello All,
I have just installed SoftEther VPN on a Linux server and it seems to be running well as default.
Now I would like to add the VPN Gate connection, but the images says to look for "VPN Gate Setting" button on the main manager page and it does not appear to be there.
https://www.vpngate.net/en/join.aspx
How can I set up the VPN Gate by creating a new HUB for it in my existing setup?
LonnieTC
Re: Setting up VPN Gate not found
Post by LonnieTC » Tue Sep 08, 2020 1:44 pm
Hello All,
Does anyone know why the "VPN Gate Settings" Button is not showing up after I connect to it to manage the freshly installed server?
I have been trying to setup a new VPN Gate Server to volunteer a server to the VPN Gate project but I do not get the button showing up.
Is there a way to set it up manually by adding a "VPN Gate" virtual hub or something?
