Windows 10 - A required certificate is not within its validity period when verifying against the current system clock
thejae
Post by thejae » Tue Dec 01, 2020 3:56 am
Trying to connect a Windows 10 to another windows 10 and am getting this error when trying to connect with SSTP (through vpnazure.net)
A required certificate is not within its validity period when verifying against the current system clock or the timestamp in the signed file
I have already made sure both clocks are the same and synchronized with the same time server. Restarted both machines twice.
Re: Windows 10 - A required certificate is not within its validity period when verifying against the current system cloc
Post by cedar » Tue Dec 01, 2020 7:54 am
It looks like the server certificate for the VPN Azure service has expired.
thejae
Post by thejae » Thu Dec 03, 2020 2:12 am
Thanks for getting back, it looks like the issue has been resolved with VPN Azure service.
Cheers to the team behind this!
