VPN port sharing SSL and OpenVPN?
nobody12
Post by nobody12 » Wed Feb 17, 2021 1:08 pm
I changed the openvpn port to 443, which is already used by the native protocol and SSTP.
However OpenVPN access and the SE protocol work still fine.
No need to use a different port for different VPN protocols.
Is this a known feature? Or should I better avoid sharing the port for OpenVPN and SSL?
