Hi
I am looking to setup a linux server with SoftEther, but I would like to have it operate both as a server and a client.
Essentially, I have a commercial VPN that I wish to use when I choose (as a client on OpenVPN). But I also need to connect another site on a bridge so that that remote site receives IP addresses from the same DHCP server (router) as all local LAN devices.
Is this possible? I do have 2 NIC in the server...
Thanks
Server Client simultaneously
Re: Server Client simultaneously
SoftEther can operate both as a server and a client, but not OpenVPN client. SoftEther has only OpenVPN server option.
As for the second part of your question, no problem, simply add a bridge on the server and the remote site will receive DHCP via its own bridge to all net devices.
Pseudomax
@solo, many thanks for the reply...
So if I understand correctly, I will need to have both SoftEther and OpenVPN installed. Would I need to bind each to a separate NIC or can I simply use different ports?
I have not used SoftEther previously... so (as a noob) I would greatly value a step by step tutorial in setting up a Linux bridge (with obfuscation). I travel (when the world is not locked down) and my home TV provider limits my remote viewing outside the country by inspecting packets for VPN traffic. So given the premium I pay for the TV I would like to make sure I can watch when I choose...
OpenVPN client will create a virtual NIC for you. SoftEther has extensive documentation with step-by-step tutorials, so no point repeating them here. However may I suggest something else for the commercial VPN access - get a small (pocket-like) "GL.iNet" router and use its OpenVPN client. It offers WiFi and Ethernet for both WAN and LAN - very convenient for travel.
Pseudomax
Thank you @solo ... I just bought "GL.iNet" router on the back of your post!
I will take a closer look at all the documentation for setting things up!
Also, your answer on the virtual NIC for OpenVPN makes sense to me now. Is this also true for SoftEther?
I have a few of these routers. Some of them on alternative DD-WRT or OpenWrt firmware. In OpenWrt it is possible to install SoftEther too.
Yes, SoftEther client creates a virtual NIC, and SoftEther server can bridge to existing NICs.
