VPN connecting to any PORT
Boris-RUS
Post by Boris-RUS » Fri Mar 05, 2021 9:02 am
Hello! i found this problem: from any host(home,office,smartphone) connecting to VPN manager is occurs on any port. For example: local address of VPN server in 10.1.1.250 and only 1194 port is listening. I can connect ONLY by 1194 port. But from the Internet (for example 94.123.233.21:"#port") connetc occurs even there is no PORT-FORWARDING on Router. It`s bag or feature of Softether VPN?
Re: VPN connecting to any PORT
Post by solo » Fri Mar 05, 2021 11:09 am
It is a feature - NAT Traversal using UDP hole punching.
