Access local server using VPN
cSaller
Post by cSaller » Tue Mar 23, 2021 5:45 pm
I have SoftEther Server running on a Windows machine on AWS and I want to use the same machine to host another application that needs to be accessible only by VPN customers, but I'm having trouble doing this.
My current scenario is:
AWS Machine
|-> SoftEther Server
|-> Another publicly accessible server
And I need:
AWS Machine
|-> SoftEther Server
|-> Another server accessible only by VPN clients
Re: Access local server using VPN
Post by solo » Tue Mar 23, 2021 9:25 pm
Add another hub with SecureNAT including VNAT and VDHCP.
cSaller
Post by cSaller » Wed Mar 24, 2021 12:45 am
Hey @solo, thanks for replying
I currently have a hub with SecureNAT enabled with all these items configured like this
Do I need to create another one with the same configuration, but changing some parameters? I couldn't quite understand the method you went through
Post by solo » Wed Mar 24, 2021 8:51 am
The reasoning method is simple. When you say "use the same machine to host another application that needs to be accessible only by VPN customers, but I'm having trouble" means that you either are not using SecureNAT, or don't understand it.
As we now know that you use SecureNAT already, access an app on the host via VPN with server-IP:app-port address. No trouble at all, but check the firewall.
