file sharing between 2 mobile 4G wifi routers ?
isoftether
Post by isoftether » Sun Apr 25, 2021 7:18 am
Hi, is there a way to use SoftEther VPN to enable two users who are using mobile 4G wifi routers (and don't know their private IP address) to directly share files over the Internet ?
sky59
Re: file sharing between 2 mobile 4G wifi routers ?
Post by sky59 » Sun Apr 25, 2021 10:52 am
If about 1MB download is enough you can use Azure cloud provided by SoftEther
isoftether
Post by isoftether » Sun Apr 25, 2021 5:19 pm
no we're talking big files, like 500Mb and up...
sky59
Post by sky59 » Mon Apr 26, 2021 3:10 am
Then you need one of the computers to be server with public ip, I have such sim card but it is unusual and i doubt you get it
Or you use raspberry pi with public ip as server and two 4g will connect to it, it must have public ip
