is it possbile to run vpnclient service at user mode
herb
Post by herb » Fri May 14, 2021 8:31 am
I wonder if it is possible to run vpnclient.exe /service at user mode? i tried vpnclient.exe /usermode, but it does not work.
Re: is it possbile to run vpnclient service at user mode
Post by solo » Sat May 15, 2021 10:15 am
vpnclient.exe /usermode works for sure but you need to run it as admin.
Also run
vpnclient.exe /stop
vpnclient.exe /uninstall
to remove service mode startup.
herb
Post by herb » Tue May 18, 2021 2:38 am
Is there any specific reason that it needs to be run with admin? I want to use it with unelevated user and take packets from named pipe instead of virtual adapter.
