IP not assigned to Softether VPN clients
azizbekoff
I have installed SoftEtherVPN Server on Windows Server 2012 R2(on Vmware Esxi Host). Client is installed on Windows 7.
VPN Client can connect. but IP not assigned by DHCP
configured with local bridge. SecureNAT disabled.
Added second NIC with no IP
Additional details:
Local bridge is added, pointed to second NIC with no IP(VMXNET3)
1st Virtual network adapter:Intel type:e100e
Promiscuous mode: Allowed
Any suggestions are appreciated!
With best regards,
azizbekoff
Additional details:
With best regards,
azizbekoff
eddiewu
Re: IP not assigned to Softether VPN clients
Is there a dhcp server on the second nic?
azizbekoff
No as described in Softethernet manual "No Protocol Stack is Used for the Local Bridge Network Adapter" Only selected on Second NIC SoftEther Lightweight Network protocol
eddiewu
In the network the second NIC connects to, is there a DHCP server? I should ask this way.
Also, is the second NIC in promisc mode too?
azizbekoff
eddiewu
I don’t understand. What do you mean by promisc mode at vlan level? If the nic is virtualized, promisc mode needs to be applied from the top level.
azizbekoff
Promisc mode now enabled on vSwitch (on top level as you mentioned)
Client can connect to vpn, but cant get ip address and cant access network Please HELP!!!
kaleem333
I have configured softether vpn server and i have a static ip as well.
When i try to access from other client pc ,,it;s connected to the static public ip and port but the vpn adpater not getting any ip from dhcp
what should i do now.
kaleem333
I have a laptop and hypver-v manager enable and on it sofether installled on vm .One virtual adapter created from hyperv which is bridget with the laptop wifi,i can't separte it because the hyperv will lost the connectity and softether as well.
Yes you can "separate" it. Again, remove local bridge (the one within SE) and enable SecureNAT, and SE clients will get proper DHCP assignments.
Next, enable Virtual NAT, and SE clients will get connectivity.
kaleem333
Hi please check the attacehmen when bridged and bridged removed.and let me know how to make the adapter workable without bridge.solo wrote: ↑Tue Mar 22, 2022 5:46 pmYes you can "separate" it. Again, remove local bridge (the one within SE) and enable SecureNAT, and SE clients will get proper DHCP assignments.
Hello, I wrote "remove local bridge (the one within SE) and enable SecureNAT", and it will work for sure.kaleem333 wrote: ↑Tue Mar 22, 2022 6:50 pmHi please check the attacehmen when bridged and bridged removed.and let me know how to make the adapter workable without bridge.
Incidentally, if you enable "MAC Address Spoofing" in advanced settings of the virtual NIC, your current config may work too.
kaleem333
yes' it's working now ,but what is reason of local bridge and i have a loacl bridge in my office it's working fine but not softether on my laptop not working the local bridge why?solo wrote: ↑Tue Mar 22, 2022 9:02 pmHello, I wrote "remove local bridge (the one within SE) and enable SecureNAT", and it will work for sure.
Yes SecureNAT is great. If you insist on a bridged connection then a vNIC with "MAC Address Spoofing" and NIC in promiscuous mode are required. That's why.
Either bridge to the LAN adapter or try a better WiFi adapter.
