the SoftEther VPN 4.0 client (Ver 4.34, Bulid 9745) doesn´t connect to any server, suddenly!
I´m using it under Windows XP and it worked very well until last monday.
The virtual VPN- client serves the message: "A network cable is not connected"
Are there known problems or are there some adjustments neccessary, now?
Can anybody help me?
After days and nights of inquiry I found the solution. And it was very very easy!
So I will give this small information to all of the other guys who have the same problem.
This is what this forum is for:
I only changed the port form 443 to 444 and erverything works perfect again. That´s all.
SoftEther VPN Client doesn´t connect to the Web (Solved)
GG2020
