I can install the client and manager, program launches and runs fine. Fails when I try to install a virtual adaptor. My question is: reading all the information about the versions available for download, is ultimately my issue the ARM architecture. I think that it is. However, if someone has encountered this and overcome it I would be interested in your account.
2nd, is it possible to manually install a virtual adaptor (I know I can do this under Windows in the adaptor section) but how would I marry it back to the SoftEther Manager?
Windows 11 ARM
timsoft
Re: Windows 11 ARM
+1 can't add virtual network adaptor on Windows 11 ARM.
Re: Windows 11 ARM
This CPU is not on the list...
https://www.softether.org/3-spec#Supported_CPUsSupported CPUs
Windows
Intel x86 (32bit), Intel x64 (64bit)
