Hi all,
I'm trying to connect to my business VPN with my Android devices following the official guide:
https://www.softether.org/4-docs/2-howt ... ient_Setup
Unfortunatelly the connection is not working.
I checked also the server configuration and I think is correct:
https://www.softether.org/4-docs/2-howt ... VPN_Server
What can I check or do to understand what is the issue?
Can I use an Android application to establish the VPN connection?
Let me know if you need some screenshots.
Thanks in advance and regards,
Giuseppe
Unable to connect via Android devices
eddiewu
Re: Unable to connect via Android devices
You provided so little information. There can be a tons of reasons why the connection failed. What have you tried to make sure the server is working ? Do you have other devices?
