Hi All,
I have found that there are a number of Chrome Browser Extensions for VPN (i.e. 1ClickVPN, OpenVPN, etc.) but I am wondering if there is one for the SoftEther (client) that could be used to connect to SoftEther VPN Gate, for example, or other SoftEther VPN server?
Any ideas or information would be greatly appreciated.
Thanks
SoftEther Chrome Browser VPN extension (client)?
LonnieTC
PH-IT
Re: SoftEther Chrome Browser VPN extension (client)?
Basically you should be able to use any OpenVPN client.
Did you tried?
Did you tried?
LonnieTC
I had understood that I could use an OpenVPN client, but I think that the SoftEther protocol is faster and better which is why I was looking for that one, in particular.
Thanks for your reply to my inquiry
