Hello!
First of all I am new to linux system.
I have set up a softether VPN server on VPS (hostsailor XEN virtualization) by a guide on the site: https://secfall.com/ustanovka-i-nastroy ... tther-vpn/
I have successfully connected to this VPN on windows desktop PC and on android phone. But I cannot do the same on linux system.
Here's server's config https://pastebin.com/umyFnBUb
And ipt-set on vps as the guide said https://pastebin.com/PHuPD0r4
As the guide suggested all logs are disabled, but I enabled them and here they are https://pastebin.com/rTyPzBYn
I have found some info that I need to manually set ip route on linux https://www.cactusvpn.com/tutorials/how ... -on-linux/
But I've failed
also command
sudo dhclient vpn_vpn
doesn't do anything, it just hangs in a loop
Can you help me, please?
