Getting SE working with just WIFI
atlbcliff
All - does anyone have a good wiki to make SE work with just a WIFI connection, as i am not able to bring the WiFI adapter in the bridging screen and even though i have enabled secure NAT as described in the forum, clients are not able to connect at all. I am also using the vpnazure way and i get the same behavior. Can pointers are helpful and once i can get it working, i can post the same in a wiki for anyone in the future.
Re: Getting SE working with just WIFI
https://www.softether.org/4-docs/1-manu ... cuous_ModeSome network adapters and network adapter drivers may not support promiscuous mode. network adapters which do not support promiscuous mode cannot, in principle, be used for local bridging with the VPN Server / VPN Bridge. Most network adapters, however, do support promiscuous mode and can be used without any problems. Below are some typical examples of network adapters which do not support promiscuous mode.
Wireless LAN (IEEE802.11) network adapters.
All other network adapters with device drivers incapable of moving to promiscuous mode.
No need for a wiki, simply find a wifi adapter supporting promiscuous mode. Refer to Kali Linux recommendations as promiscuous mode is essential to its operations. Here is "Best WiFi Adapter for Kali Linux".
