Huge and suspicious 'Server logs'
emorlion
Post by emorlion » Fri Oct 15, 2021 11:19 am
For some time, i have been checking the logfiles from Softether: huge logfiles are being generated daily (approx. 300-400 MB/day !!)
See small extract in attachment.
To say the least, the content seems very suspicious to me.
Softether is installed on a Raspberry Pi, which is not connected to the internet directly: it has a static PRIVATE IP address and i connect through Port Forwarding in my router.
In the attached logfile, i masked the Raspberry's private IP address with "MyPrivateIP.33"
Anyone has any idea where this can originate from and how to resolve?
Thanks,
Eddy
Re: Huge and suspicious 'Server logs'
Post by cedar » Thu Oct 28, 2021 10:19 am
You look like you are under attack.
Please stop UDP port forwarding if you don't need it.
