RDP connection to Host IP 192.168.30.1
ralvesson
Post by ralvesson » Tue Oct 26, 2021 2:24 pm
Hi I have been trying to connect to my VPN host form a VPN Client machine using RDP to 192.168.30.1 but with no success...any advise as to how to achieve it? I have Virtual NAT and Virtual DHCP on in my VPN Hub. Thanks in advance.
Re: RDP connection to Host IP 192.168.30.1
Post by solo » Wed Oct 27, 2021 12:39 am
In your described SE configuration you do not RDP-connect to IP 192.168.30.1 but to an RDP address on SE Server's LAN subnet, eg 192.168.1.111
ralvesson
Post by ralvesson » Wed Oct 27, 2021 6:41 am
Hi. Thanks for your reply. Quick question. For example: If my SE client assigned my connection the IP address .30.11 and my server's local subnet is completely different (e.g. 50,22) would my SE hub connect me to it ? For routing purposes how would my local client PC would know to send packets to 50.22 through the SE tunnel ? Thanks again
Post by solo » Wed Oct 27, 2021 9:56 am
Since you enabled Virtual NAT, your SE client's IP is masqueraded and appears as the SE server's IP on the LAN.
ralvesson
Post by ralvesson » Wed Oct 27, 2021 12:05 pm
Hi thanks for your reply.
You wrote: "Since you enabled Virtual NAT, your SE client's IP is masqueraded and appears as the SE server's IP on the LAN." Since as mentioned my SE srver's IP is 192.168.50.22 then. I ask, in the Microsoft RDP client screen on my client PC what exactly should I type to connect via RDP to the server?
Post by solo » Wed Oct 27, 2021 12:12 pm
192.168.50.22
PH-IT
Post by PH-IT » Thu Jan 20, 2022 10:31 pm
Check the routing at client side
Windows
tracert -d 1.1.1.1
Linux
traceroute -I 1.1.1.1
Further you need to push routes to the client if using split-tunneling
