Connect a client to a server from command line
ZEE
Post by ZEE » Tue Nov 30, 2021 10:52 pm
Need a recipe to configure and connect from a client to a server from command line
(a video detailing the process would be nice... Using Windows 10)
From the server side I don't have any problem
I start the server in USER-MODE...
and I can test/connect OK from a client configured with VPNCMGR.EXE...
I'm struggling with connecting a client to the same server
only from command line (no client installation done or intended)
I can start the client in USER-MODE and it stays in the tray... but:
?how do I connect to the remote server...
?specify the remote address (host:port)
?specify the hub I want to connect
?specify the credentials
?what is the command line tool to use and HOW TO USE IT???
