I have reinstalled SoftEther Bridge after an unsuccessful attempt with full server installation.
I am a newbie to this and I was hoping to see the Easy Setup GUIs.
However, I didn't see these and even when I create a new "Connection Settings for VPN Server" and hit connect it assumed the User Name is Administrator. While historically I know the password, the next screen is the "Manage VPN Bridge "localhost".
How can I (re)start from scratch?
How do I reset configuration to see the "Easy Setup" GUI?
Mikexx
Re: How do I reset configuration to see the "Easy Setup" GUI?
- uninstall current version
- delete SoftEther's folder from "Program Files"
- remove the following registry keys
[-HKEY_CURRENT_USER\Software\SoftEther Corporation]
[-HKEY_CURRENT_USER\Software\SoftEther Project]
[-HKEY_CURRENT_USER\Software\University of Tsukuba]
[-HKEY_LOCAL_MACHINE\SOFTWARE\SoftEther Project]
Mikexx
Many thanks, it worked. There were also residual versions of the server as well as client directories so deleted these too.solo wrote: ↑Mon Jan 17, 2022 10:32 pm
[-HKEY_CURRENT_USER\Software\SoftEther Corporation] [-HKEY_CURRENT_USER\Software\SoftEther Project] [-HKEY_CURRENT_USER\Software\University of Tsukuba] [-HKEY_LOCAL_MACHINE\SOFTWARE\SoftEther Project]
BTW I didn't find:
Or indeed any reference to "Tsukuba" in the registry apart from cached references to programs.
