I installed the softener VPN on the church server. I can vpn while on the church network but from home I am not able to connect. Please advised
Jdezel
Cannot connect to my church server
Re: Cannot connect to my church server
Do we have to pray for details of your setup?
eddiewu
That sounds like the server or its gateway router has not opened the port.
sky59
Your server most likely does not have public IP address.
dsholm
On your firewall you need to do two things.
1. Forward port 443 to your Softether VPN Server.
2. Allow port 443 to your Softether or to the public interface (all firewalls work different, but most will use the private IP of the VPN server that you forwarded port 443 to). Sometimes this step is implied when you forward the port.
I made the assumption that 443 is enabled on your server which should be by default. You can verify from the application or run:
netstat -anp tcp | find ":443"
