VPN client can ping only to the VPN Server
elkos
Post by elkos » Tue Feb 01, 2022 9:04 am
Good Morning,
I have installed the VPN Server on a Windows 10 machine.
I use the SoftEther Client, and i can connect to the server.
When connecting to the vpnserver, the wifi connection get down
I can ping my windows 10 machine, but not other.
I have try with a IPSEC connection with shared key, it's make the same -> connected but wifi down and only the server can be reached.
The firewall was deactivated for these tests
Some one have an Idea ?
Thanks in advance
Re: VPN client can ping only to the VPN Server
Post by solo » Tue Feb 01, 2022 12:44 pm
Either bridge it or enable SNAT+VNAT.
elkos
Post by elkos » Wed Feb 02, 2022 7:11 am
Hi Solo, thanks for the reply.
I have tried, but no success.
After a lot of search i see the promiscuous mode was not enable on my virtual nic on the wmware machine.
Now it's ok !
Have a nice day
Post by solo » Wed Feb 02, 2022 9:02 am
...on my virtual nic on the wmware machine.
In your OP you didn't tell us it was VM.
