How to connect automatically by scripts?
Luney5215
When I select a VPN server and try to connect it, but it always prompts me that failed to connect the VPN server, then I had to double-click the icon of VPN Gate Public VPN Relay Servers again, rearrange and select the next one, and try again and again until a certain one can be connected, sometimes even fail for dozens of times. Although it's just a mechanical way to click the mouse several times, can such an operation be replaced by a script?
Re: How to connect automatically by scripts?
There is no command line access to VPN Gate Client Plugin's hosts list.
The command line features of SE VPN Client Manager are rather limited.
That said, I've just tested a usable workaround for scripted VPN Gate auto-connect. You will not like it but let's discuss and improve it.
#1 on https://www.vpngate.net/en/ pick a few of your preferred hosts.
For example currently the first top one: public-vpn-185.opengw.net
#2 in SE VPN Client Manager click 'add vpn connection' and enter:
#3 ...add as many connections as you need
#4 create this "auto-connect.bat" batch file with the above connection names:
#5 double-click on "auto-connect.bat"
It will still require to cancel a failed connection popup but it is only a single mouse click :-)
host: public-vpn-185.opengw.net
port: 443
hub: VPNGATE
user: vpn
password: vpn
@echo off
path=%path%;C:\Program Files\SoftEther VPN Client
::start
vpncmd /CLIENT localhost /CMD AccountRetrySet SRVA /NUM:0 /INTERVAL:5
vpncmd /CLIENT localhost /CMD AccountConnect SRVA
ping -n 10 127.0.0.1 >nul
vpncmd /CLIENT localhost /CMD AccountRetrySet SRVB /NUM:0 /INTERVAL:5
vpncmd /CLIENT localhost /CMD AccountConnect SRVB
vpncmd /CLIENT localhost /CMD AccountRetrySet SRVC /NUM:0 /INTERVAL:5
vpncmd /CLIENT localhost /CMD AccountConnect SRVC
:: ...etc...
::goto start
Luney5215
Thank you for your sincere reply to my question. I even think no one will pay attention to this. Although there is no script or plug-in to realize the operation I want, you do provide a good idea, and I will continue to try
