Unable to connect RDP
playstorekolagi
Help needed regarding RDP Connection. Whenever I use VPN Gate Public VPN Relay servers after that I lose connection to RDP and after that, I am unable to use RDP.
Re: Unable to connect RDP
Add a persistent static route to your RDP destination network.
playstorekolagi
can you guide me to add it on was and azure?
playstorekolagi
playstorekolagi
not working bro
post as code the output of "netstat -r" bro
fenice
Then simply try another search engine such as: https://startpage.com and use
+persistent +static +route-
playstorekolagi
it does not work on was bro I meansfenice wrote: ↑Mon Mar 14, 2022 9:19 pmThen simply try another search engine such as: https://startpage.com and useas the terms.Code: Select all
