print to remote printers
tahitiarue
Post by tahitiarue » Thu Mar 17, 2022 8:04 am
Good morning all,
I installed this jewel of program which works like a charm, but I can't capture shared printers, windows refuses to install them
a little help for me?
Tks
Re: print to remote printers
Post by solo » Thu Mar 17, 2022 8:56 am
Shared printers... shared folders... maybe you'll find a solution in the Client PC unable to reach shared directory on Server PC topic. If not, please describe your config, is it L2, L3 or SNAT VPN?
tahitiarue
Post by tahitiarue » Thu Mar 17, 2022 7:56 pm
thanks for your attention...
Shared printer et folder ok
i make a screen shoot
Post by solo » Thu Mar 17, 2022 11:04 pm
Look, the 0x0000007c error is widespread and may have nothing to do with your VPN.
tahitiarue
Post by tahitiarue » Wed Mar 23, 2022 3:00 am
Sorry but I still can't capture printers, for folders it's ok
please help me
Post by solo » Wed Mar 23, 2022 5:11 am
Are you saying that a PC directly on your LAN can "Connect to the Printer" but the same PC on VPN "Cannot Connect to the Printer"?
tahitiarue
Post by tahitiarue » Wed Mar 23, 2022 6:12 pm
Thank you for your answer
but the pc's are not in the same place
Post by solo » Thu Mar 24, 2022 10:49 am
If Windows cannot add/connect to shared printer with error "Operation Failed with error 0x0000007c: Windows Cannot Connect to the Printer", or if the installed shared printer is not responding when you try to print in Windows 10, continue reading...
That's it, continue reading about Windows' remedies, it has nothing to do with your VPN.
tahitiarue
Post by tahitiarue » Thu Mar 24, 2022 8:21 pm
I did all the steps up to method 3, and the miracle happened!!! :)
Thank you for your support and your pugnacity, I recognize there the Japanese soul
If any of you ever pass by my house, I would be happy to welcome them.
Maururu
