SERVER 2019
tahitiarue
SERVER 2019
Post by tahitiarue » Fri Mar 25, 2022 4:36 am
My friends,
when install vpn server on my server 2019, impossible to connect with my client vpn
It's a different install for Windows server 2019 ??,
thanks
Re: SERVER 2019
Post by solo » Fri Mar 25, 2022 2:11 pm
So, you got the printers working and then decided to upgrade to SERVER 2019? ;-)
It ain't different than any other OS install and SoftEther works just fine on it. Do check this thread and answer here the diagnostic questions.
tahitiarue
Re: SERVER 2019
Post by tahitiarue » Tue Apr 05, 2022 4:46 am
no sorry, it is on another computer park which is equipped with a windows server 2019
Should specific ports be opened? on the router??
Tks
