Can't connect to SoftEther server from Android
Roman
Hi!
On my virtual machine (Linux (ubuntu 20.04)) in a cloud I've created SoftEther VPN server following instruction posted here https://cloudinfrastructureservices.co. ... ntu-20-04/
I've done all the posted steps for server creation - no errors during any of it.
I can successfully connect to the server from OS Win using SoftEther client (ver 4.34 build 9745).
But I cannot connect to the server from my phone (Android 7.0).
I follow these instructions https://www.softether.org/4-docs/2-howt ... ient_Setup
But when I try to connect it's just says 'Unsuccessful'. Googling problem leads mostly to the same instructions as at the link above.
Could anyone, please, advise what to check? Maybe someone have seen the same problem?
Beside buid-in Android vpn client, is there any other free SoftEther vpn client for Android 7.0 that can connect to some custom server?
Thank you in advance!
Re: Can't connect to SoftEther server from Android
From the instructions
But you also need to allow UDP 500 and 4500.Enable L2TP over IPsec Server Function (yes / no): yes
...you will need to allow ports 443, 5555, 992 and 1194
Roman
Thank you for the reply!
Have run the commands now allowing the ports, but the problem remains
It seems like the image of the VM with disabled firewall (the line with the system reply 'Firewall not enabled (skipping reload)'), so it even more strange what can be wrong.
Any other ideas?
azureuser@VPNserver:~$ sudo ufw allow 500/udp
Rules updated
Rules updated (v6)
azureuser@VPNserver:~$ sudo ufw allow 4500/udp
Rules updated
Rules updated (v6)
azureuser@VPNserver:~$ sudo ufw reload
azureuser@VPNserver:~$Any other ideas?
This cloud has no need for port forwarding?
Can you connect to it from Windows using L2TP/IPsec?
Can your Android connect to VPN Gate using L2TP/IPsec?
Roman
I'll investigate and give an updateThis cloud has no need for port forwarding?
No. I get error: 'The L2TP connection attempt failed because the security layer encountered a processing error'Can you connect to it from Windows using L2TP/IPsec?
At the same time I can connect to VPN Gate's server via built-in Win10 VPN.
And, as quick reminder, I can successfully connect to the problem server via SoftEther client for win.
Yes.Can your Android connect to VPN Gate using L2TP/IPsec?
It seems like I missing some setting on the my server which fails connection via built-in clients (both Android 7 and Win 10).
I'll reinstall the server from the scratch and will post an update.
At the same time any other ideas appreciated! Especially maybe some other step-by-step guide for server install is recommended?
And thank you again for the replies!!!
PS
also while googling the problem have found this client https://github.com/kittoku/Minimum-VPN- ... tEther-VPN.
It's just in case if it's gonna help anyone else. I doesn't in my case as it for Android 8 or later (https://github.com/kittoku/Minimum-VPN- ... N/issues/6)
Aah yes that. You see, it is completely inconclusive because native SoftEther VPN protocol deploys neat connection tricks with NAT-T and/or VPN Azure, which are not applicable for L2TP/IPsec and your Android.
So, if necessary do port forwarding for UDP 500, 4500, 1194 and TCP 443, 5555, 992.
On the server confirm that...
netstat -uapn
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
udp 0 0 127.0.0.1:4500 0.0.0.0:* 1387/vpnserver
udp 0 0 127.0.0.1:500 0.0.0.0:* 1387/vpnserver
portqry.exe -n your.cloud.net -e 500 -p UDP
//expected reply: "UDP port 500 (unknown service): LISTENING or FILTERED"
portqry.exe -n your.cloud.net -e 4500 -p UDP
//expected reply: "UDP port 4500 (unknown service): LISTENING or FILTERED"
Roman
Yes! Got it working!
I messed up with this and had these ports closed (but not in the VM itself (where firewall is disabled) but in Azure portal settings)
Huge thanks, solo!!!!!!
You were right!So, if necessary do port forwarding for UDP 500, 4500, 1194 and TCP 443, 5555, 992.
covis
Hello solo and Roman,
I have the same problem like Roman but difference is that I have SoftEther server instaled on VM Azure on Windows10.
When I use SoftEther Client for Windows the connection is established.
On the VM Azure Windows10 I disabled firewall.
When I try connect by my phone with Android or my iPad Pro I see message 'Unsuccessful'
I attached screens with rules Inbound and Outbound ports
Could you explain me most simply how setup port forwarding at setup Azure and VM with Windows10?
Or am I making another mistake as well?
Hi covis, the inbound firewall rules seem OK, check Azure port forwarding and allow all outbound traffic in the firewall.
Roman
Hi! tiny conformation from my side: yes, I tweaked the port setting in the same way: 'Networking' menu item. Firewall on the VM itself was disabled right after creation (but it depends on which VM image used I guess)
covis
Thank you solo and Roman.
Solutions is of course port forwarding and using Virtual NAT and Virtual DHCP Server with collaboration of OpenVPN Clients on Android and IOs equipment.
I use VM with Windows10 and it is Windows ;-)
I must use it (Windows not Linux) because I have applications for Windows running on VM.
jhs
Hi, it would seem that forwarding ports 500 and 4500 is necessary for android devices to connect to a Softether VPN server. My problem is that I have a device in my network that is already been forwarded ports 500 and 4500 to. In such case, what can be done to get my android device connected to my Softether VPN server?
Thanks.
Thanks.
AKUM4
Thankyou @solo and @jhs, I have been struggling with this for 2 days.
