Fresh Install of Softether Server - Doesn't see Local Adapters NICs
shaywood
Post by shaywood » Fri Apr 15, 2022 12:11 am
Hello, just installed Softether on a Windows 11 PC that has 4 Network adapters (2 Realtec NICs, Virtualbox VM adapter and a Wifi adapter). During installation Softether only shows Virtualbox as a local bridge option. Any idea why I can't see the NICs? I have reinstalled and rebooted. Other programs, like Virtualbox, can see all the network adapters.
Re: Fresh Install of Softether Server - Doesn't see Local Adapters NICs
Post by solo » Fri Apr 15, 2022 11:16 am
Perhaps it is a SE-W11 compatibility issue? You could report it here https://github.com/SoftEtherVPN/SoftEtherVPN/issues
But first, can you see on the Ethernet NICs the following:
(PS)> Get-NetAdapter | Select *
Status : Up
PromiscuousMode : True
(WiFi usually does not support Promiscuous Mode and can not be bridged)
shaywood
Post by shaywood » Fri Apr 15, 2022 1:10 pm
Thank you. Both NIC's are "Up", but PromiscuousMode is "False" on 1 of them.
Post by solo » Fri Apr 15, 2022 10:54 pm
Can Wireshark "sniff" on the Realtecs in Promiscuous Mode?
Try the latest SoftEther nightly build. If still unresolved, report it at the above github link. Please update us here as it is a very interesting issue.
shaywood
Post by shaywood » Sun Apr 17, 2022 4:52 am
Added a broadcom nic, which Softether was able to see. Thanks for the help.
