Setup works but no connection to LAN servers possible
JAG
Hi everyone,
I've just setup a Windows Server with Softether Server and a Windows Client with Softether client.
Then I setup a connection to the VPN server.
Connection from client works to VPN server. Status is connected. The Client got IP address from Virtual DHCP-server.
The client can ping server. The server can ping client.
So far so good.
What doesn't work is that if I ping or try to RDP servers in the LAN, after successfully being connected to the VPN server they cannot be pinged? What should I configure to enable this so that servers can be pinged?
Greetings, Alex
So far so good.
Greetings, Alex
Re: Setup works but no connection to LAN servers possible
Just a moment, not so good actually. "Virtual DHCP-server" implies SecureNAT and in this networking scenario you have reported unbelievably successful pings. This miracle can only happen if you are running SoftEther server and client on the same PC. It is a truly useless test setup.
Going forward, while RDP over SecureNAT is doable, you will not like it. Please review Client PC unable to reach shared directory on Server PC for the reasons why not.
JAG
Hi Solo,
Thanks for your reply.
Actually, it is a regular VPN server and VPN client setup. Server runs in a datacenter and client remotely connects from outside datacenter.
This is a setup that I've implemented at customers before. Also with (secure)NAT.
When there is no IP address pool configured, clients will get a APIPA address (169.254.x.x). This means that there is no DHCP server available or a connection can be made to a DHCP server. That's why a Virtual DHCP server comes into the game and gives a successfully connected client an IP address.
By enabling SecureNAT and the Virtual DHCP server a remotely connected PC gets an IP address from the configured IP pool. That's how VPN always has been working for sofar I know. That's also why the virtual DHCP server always is able to ping the client and vice versa. So, that's good and expected behavior.
The thing that's missing in my opinion is an route for the Virtual DHCP pool to be able to route the traffic from the VPN Virtual DHCP to the actual internal LAN. Adding this route unfortunately doesn't solve the problem.
Please post the output of "netstat -r" and "ipconfig /all" after VPN connection from both server and client, and paste them as code. Also include a log of pings to client/server. For example:
ipconfig /all
Ethernet adapter VPN - VPN Client:
Description . . . . . . . . . . . : VPN Client Adapter - VPN
Physical Address. . . . . . . . . : 5E-D4-B1-2F-81-01
Dhcp Enabled. . . . . . . . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.30.10
DHCP Server . . . . . . . . . . . : 192.168.30.1
netstat -r
Active Routes:
0.0.0.0 0.0.0.0 10.0.2.2 10.0.2.15 20
10.0.2.0 255.255.255.0 10.0.2.15 10.0.2.15 20
10.0.2.15 255.255.255.255 127.0.0.1 127.0.0.1 20
10.255.255.255 255.255.255.255 10.0.2.15 10.0.2.15 20
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
130.158.6.107 255.255.255.255 10.0.2.2 10.0.2.15 20
192.168.30.0 255.255.255.0 192.168.30.10 192.168.30.10 1
192.168.30.10 255.255.255.255 127.0.0.1 127.0.0.1 1
192.168.30.255 255.255.255.255 192.168.30.10 192.168.30.10 1
224.0.0.0 240.0.0.0 10.0.2.15 10.0.2.15 20
224.0.0.0 240.0.0.0 192.168.30.10 192.168.30.10 1
255.255.255.255 255.255.255.255 10.0.2.15 10.0.2.15 1
255.255.255.255 255.255.255.255 192.168.30.10 192.168.30.10 1
Default Gateway: 10.0.2.2
ping 192.168.30.10
Pinging 192.168.30.10 with 32 bytes of data:
Reply from 192.168.30.10: bytes=32 time<1ms TTL=128
ping 192.168.30.1
Pinging 192.168.30.1 with 32 bytes of data:
Reply from 192.168.30.1: bytes=32 time<1ms TTL=128
While waiting for your logs I realized that yet another network topology, as bad and unthinkable as SE client/server on the same PC, can produce the results you described. Have you enabled both local bridge and SecureNAT/vDHCP? If so, there is no way it could possibly work, choose one or the other.
SecureNAT in this context refers to the "Virtual NAT Function".
JAG
C:\Users\jag>ping 192.168.178.230
Pinging 192.168.178.230 with 32 bytes of data:
Reply from 192.168.178.230: bytes=32 time=2ms TTL=128
Reply from 192.168.178.230: bytes=32 time=3ms TTL=128
Ping statistics for 192.168.178.230:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 2ms, Maximum = 3ms, Average = 2ms
C:\Users\jag>netstat -r
Interface List
53...5e d2 db 1c 6c 60 ......VPN Client Adapter - VPN
6...f4 a4 75 f9 34 28 ......Microsoft Wi-Fi Direct Virtual Adapter
2...f6 a4 75 f9 34 27 ......Microsoft Wi-Fi Direct Virtual Adapter #2
19...f4 a4 75 f9 34 27 ......Intel(R) Wi-Fi 6 AX201 160MHz
20...f4 a4 75 f9 34 2b ......Bluetooth Device (Personal Area Network)
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 192.168.178.1 192.168.178.75 50
89.101.251.228 255.255.255.255 192.168.178.1 192.168.178.75 50
127.0.0.0 255.0.0.0 On-link 127.0.0.1 331
127.0.0.1 255.255.255.255 On-link 127.0.0.1 331
127.255.255.255 255.255.255.255 On-link 127.0.0.1 331
130.158.6.75 255.255.255.255 192.168.178.1 192.168.178.75 50
192.168.178.0 255.255.255.0 On-link 192.168.178.75 306
192.168.178.0 255.255.255.0 On-link 192.168.178.231 257
192.168.178.75 255.255.255.255 On-link 192.168.178.75 306
192.168.178.231 255.255.255.255 On-link 192.168.178.231 257
192.168.178.255 255.255.255.255 On-link 192.168.178.75 306
192.168.178.255 255.255.255.255 On-link 192.168.178.231 257
224.0.0.0 240.0.0.0 On-link 127.0.0.1 331
224.0.0.0 240.0.0.0 On-link 192.168.178.75 306
224.0.0.0 240.0.0.0 On-link 192.168.178.231 257
255.255.255.255 255.255.255.255 On-link 127.0.0.1 331
255.255.255.255 255.255.255.255 On-link 192.168.178.75 306
255.255.255.255 255.255.255.255 On-link 192.168.178.231 257
Persistent Routes:
None
IPv6 Route Table
Active Routes:
If Metric Network Destination Gateway
19 306 ::/0 fe80::4ad3:43ff:fec9:2870
1 331 ::1/128 On-link
19 306 2001:1c01:43c4:8800::/64 On-link
19 306 2001:1c01:43c4:8800:309d:8ce3:344f:4fd3/128
On-link
19 306 2001:1c01:43c4:8800:899e:19f0:a648:f45a/128
On-link
19 306 fe80::/64 On-link
53 291 fe80::/64 On-link
53 291 fe80::204f:9ce6:2c7c:fb18/128
On-link
19 306 fe80::309d:8ce3:344f:4fd3/128
On-link
1 331 ff00::/8 On-link
19 306 ff00::/8 On-link
53 291 ff00::/8 On-link
Persistent Routes:
None
C:\Users\jagor>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : ALEXWORK03
Primary Dns Suffix . . . . . . . :
DNS Suffix Search List. . . . . . : prdlab.nl
Unknown adapter VPN - VPN Client:
Connection-specific DNS Suffix . : prdlab.nl
Physical Address. . . . . . . . . : 5E-D2-DB-1C-6C-60
Link-local IPv6 Address . . . . . : fe80::204f:9ce6:2c7c:fb18%53(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.178.231(Preferred)
Lease Obtained. . . . . . . . . . : woensdag 27 april 2022 08:46:06
Lease Expires . . . . . . . . . . : woensdag 27 april 2022 15:46:49
DHCP Server . . . . . . . . . . . : 192.168.178.230
DHCPv6 IAID . . . . . . . . . . . : 895406811
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-29-42-11-38-3C-18-A0-19-1F-EC
DNS Servers . . . . . . . . . . . : 192.168.1.1
Wireless LAN adapter LAN-verbinding* 1:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : F4-A4-75-F9-34-28
Wireless LAN adapter LAN-verbinding* 2:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : F6-A4-75-F9-34-27
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Intel(R) Wi-Fi 6 AX201 160MHz
Physical Address. . . . . . . . . : F4-A4-75-F9-34-27
IPv6 Address. . . . . . . . . . . : 2001:1c01:43c4:8800:309d:8ce3:344f:4fd3(Preferred)
Temporary IPv6 Address. . . . . . : 2001:1c01:43c4:8800:899e:19f0:a648:f45a(Preferred)
Link-local IPv6 Address . . . . . : fe80::309d:8ce3:344f:4fd3%19(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.178.75(Preferred)
Lease Obtained. . . . . . . . . . : woensdag 27 april 2022 08:45:29
Lease Expires . . . . . . . . . . : woensdag 27 april 2022 15:03:24
Default Gateway . . . . . . . . . : fe80::4ad3:43ff:fec9:2870%19
192.168.178.1
DHCP Server . . . . . . . . . . . : 192.168.178.1
DHCPv6 IAID . . . . . . . . . . . : 200582261
DNS Servers . . . . . . . . . . . : 2001:b88:1002::10
2001:b88:1202::10
2001:730:3e42:1000::53
89.101.251.228
89.101.251.229
Ethernet adapter Bluetooth-netwerkverbinding:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : F4-A4-75-F9-34-2B
C:\Users\jag>
JAG
And now from the server:
Microsoft Windows [Version 10.0.20348.405]
(c) Microsoft Corporation. All rights reserved.
C:\Users\administrator.prdlab>netstat -r
Interface List
9...00 50 56 89 9c cd ......vmxnet3 Ethernet Adapter
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 192.168.178.1 192.168.178.106 271
192.168.178.0 255.255.255.0 On-link 192.168.178.106 271
192.168.178.106 255.255.255.255 On-link 192.168.178.106 271
192.168.178.255 255.255.255.255 On-link 192.168.178.106 271
224.0.0.0 240.0.0.0 On-link 192.168.178.106 271
255.255.255.255 255.255.255.255 On-link 192.168.178.106 271
Persistent Routes:
Network Address Netmask Gateway Address Metric
0.0.0.0 0.0.0.0 192.168.178.1 Default
IPv6 Route Table
Active Routes:
Persistent Routes:
None
C:\Users\administrator.prdlab>ipconfig/all
Host Name . . . . . . . . . . . . : MT01
Primary Dns Suffix . . . . . . . : prdlab.nl
Ethernet adapter Ethernet0:
Description . . . . . . . . . . . : vmxnet3 Ethernet Adapter
Physical Address. . . . . . . . . : 00-50-56-89-9C-CD
IPv4 Address. . . . . . . . . . . : 192.168.178.106(Preferred)
Default Gateway . . . . . . . . . : 192.168.178.1
DNS Servers . . . . . . . . . . . : 192.168.178.220
192.168.178.1
C:\Users\administrator.prdlab>ping 192.168.178.1.231
Ping request could not find host 192.168.178.1.231. Please check the name and try again.
C:\Users\administrator.prdlab>ping 192.168.178.230
Reply from 192.168.178.230: bytes=32 time<1ms TTL=128
Minimum = 0ms, Maximum = 0ms, Average = 0ms
C:\Users\administrator.prdlab>-
Alex, your SE client seems to connect via WiFi to the same LAN as the SE server. Can you connect it on a different network, eg a hotspot on your cell phone and repeat the ping tests?
Btw there is a typo error "Ping request could not find host 192.168.178.1.231."
Again, have you enabled both local bridge and SecureNAT/vDHCP?
JAG
Yes, I have not enabled local bridge on the VPN server and enabled SecureNAT/vDHCP.
JAG
From client (connected through 4G):
Reply from 192.168.178.230: bytes=32 time=119ms TTL=128
Reply from 192.168.178.230: bytes=32 time=71ms TTL=128
Reply from 192.168.178.230: bytes=32 time=80ms TTL=128
Reply from 192.168.178.230: bytes=32 time=91ms TTL=128
Minimum = 71ms, Maximum = 119ms, Average = 90ms
C:\Users\jag>ipconfig /all
Lease Obtained. . . . . . . . . . : woensdag 27 april 2022 16:04:39
Lease Expires . . . . . . . . . . : woensdag 27 april 2022 18:04:39
DNS Servers . . . . . . . . . . . : 192.168.178.1
IPv6 Address. . . . . . . . . . . : 2a02:a420:6:1f02:309d:8ce3:344f:4fd3(Preferred)
Temporary IPv6 Address. . . . . . : 2a02:a420:6:1f02:44d5:3d5b:cf4c:b7e8(Preferred)
IPv4 Address. . . . . . . . . . . : 172.20.10.6(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.240
Lease Obtained. . . . . . . . . . : woensdag 27 april 2022 15:59:32
Lease Expires . . . . . . . . . . : donderdag 28 april 2022 15:59:32
Default Gateway . . . . . . . . . : fe80::4c20:b8ff:fe9d:9664%19
172.20.10.1
DHCP Server . . . . . . . . . . . : 172.20.10.1
DNS Servers . . . . . . . . . . . : fe80::4c20:b8ff:fe9d:9664%19
172.20.10.1
Interface List
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 172.20.10.1 172.20.10.6 50
80.115.26.165 255.255.255.255 172.20.10.1 172.20.10.6 50
130.158.6.75 255.255.255.255 172.20.10.1 172.20.10.6 50
172.20.10.0 255.255.255.240 On-link 172.20.10.6 306
172.20.10.6 255.255.255.255 On-link 172.20.10.6 306
172.20.10.15 255.255.255.255 On-link 172.20.10.6 306
224.0.0.0 240.0.0.0 On-link 172.20.10.6 306
255.255.255.255 255.255.255.255 On-link 172.20.10.6 306
Persistent Routes:
None
IPv6 Route Table
Active Routes:
19 306 ::/0 fe80::4c20:b8ff:fe9d:9664
19 306 2a02:a420:6:1f02::/64 On-link
19 306 2a02:a420:6:1f02:309d:8ce3:344f:4fd3/128
On-link
19 306 2a02:a420:6:1f02:44d5:3d5b:cf4c:b7e8/128
On-link
On-link
On-link
Persistent Routes:
None
C:\Users\jag>
JAG
From server:
C:\Users\administrator.prdlab>ping 192.168.178.231
Pinging 192.168.178.231 with 32 bytes of data:
Request timed out.
Request timed out.
Reply from 192.168.178.106: Destination host unreachable.
Ping statistics for 192.168.178.231:
Packets: Sent = 4, Received = 2, Lost = 2 (50% loss),
C:\Users\administrator.prdlab>ipconfig /all
192.168.178.1
Interface List
IPv4 Route Table
Active Routes:
Persistent Routes:
IPv6 Route Table
Active Routes:
Persistent Routes:
None
Thank you. As you can see "the server can ping client" is not true on SecureNAT when the VPN LAN loop is removed and a real remote connection is established. Now we can consider your VPN objectives.
If all you want is "to RDP servers in the LAN" then do this:
- restore the default SecureNAT config (vDHCP 192.168.30.x, vNAT on, etc.)
- connect a SE client
- RDP to a LAN address 192.168.178.x
If you actually need the server to ping clients then we can accomplish it a different net config.
andrewwilliams
I am also facing the same issue.
eddiewu
This is the expected behavior. You didn't specify your situation in the right way so people were frustrated to understand. Your problem is to access the client-side network from the server.
SecureNAT is one-way from client to server.
To realise two-way access. You need a local bridge on the server side instead of secureNAT.
If there are more than 1 device on the client-side you would like the server to access, install SE bridge instead of SE client and setup a local bridge on the client side as well.
JAG
Thank you solo! That worked. Just recreating as you specified. With default settings. The problem was that I had the same ip address range in which the servers reside, so routing did not work as we wanted. Now it does. Thabk again solo!
JAG
