Hello All,
Maybe I am crazy, I have done the changes as outlined online to make the timeout longer for authentication with Radius due to MFA. However, after I compile and install the server. Everything works including local users. However, Radius NEVER works. I have tested with tools and verified that my Radius Server works but its like my SoftEther VPN Server is not attempting to hit the radius server.
Is it something I need to change in the source before compiling?
SoftEther VPN Source Radius Not Working
Re: SoftEther VPN Source Radius Not Working
Hi, you are not crazy, RADIUS has been removed from the source code for commercial reasons.
BABER
CONNECT TO RADIUS
Hi
I have connected the Softether server to a RADIUS server (IBSng)
Authentication is working, but when the user disconnects the connection it stays online in the RADIUS server.
How I can resolve it?>
Mohammadkz
Re: CONNECT TO RADIUS
Irani hasti? Age hasti manam ye moshkel ba ibsng daram komakam kon
hsmmaster
Hi
i want connect the IBSng server to Softether server, config the Softether server but its not working, and i don't know that configuration of IBSng server is correct or no,
can you guide me about connect IBSng server to Softether server ?
thank you
