VPN doesn't work when i'm connected with wifi
danielefornari
Post by danielefornari » Mon May 16, 2022 12:43 pm
Hello to everyone!
I have a problem, i configure Vpn server softether and i can connect and reach the server remotely only from my Iphone with mobile data, if i connect the iphone with some WiFi i can connect to vpn, get the address but i don't ping the server.
From server, instead, i can ping the client.
Please help me!! thank you!
Re: VPN doesn't work when i'm connected with wifi
Post by solo » Mon May 16, 2022 11:17 pm
Most likely the WiFi's subnet is the same as the SE server's. You need to change it.
