Using VPN server tunnel to communicate with server itself
chrisk
Dear forum members,
I installed SoftEther and setup VPN server with SecureNAT, VirtualDHCP (192.168.30.0/24) successfully.
Ping from my client (192.168.30.10) to the VPN server (192.168.30.1) works fine.
But the VPN connection couldn't be used from the VPN server back to the client, for example a ping from the server (192.168.30.1) to the
client 192.168.30.10 is not successful.
I'm looking for a solution to tunnel eclipse debugging with pydev which needs the following setup:
client -> https://webserver using the same host/ip address as VPN server
server debugging should use VPN tunnel (192.168.30.1) and connect to -> port 5678 to client (192.168.30.10)
Is this setup possible with SoftEther?
If yes, what needs to be changed in the configuration to either get a seperate interface for the private subnet (192.168.30.0/24) or to use
the VPN tunnel backwards?
Thank you for your help.
Best regards
Christof
Best regards
Christof
eddiewu
Re: Using VPN server tunnel to communicate with server itself
SecureNAT setup is internal to softether. So you won't see 192.168.30.0 assigned to the server.
Use a TAP device and local bridge instead should solve the problem, provided you are on Linux.
SoftEther offers VPN solutions in L2, L3 and SecureNAT mode. To achieve the described objectives in your preferred SecureNAT mode, install a SE client together with SE server on the same PC. The client must not use your vDHCP, set its vNIC to a static IP 192.168.30.2/24 and DG/DNS none.
chrisk
Hi Eddie,
I changed my setup according your comment. Now I'm using a bride with tap device and use a static subnet (192.168.3.0/24).
Unfortunately, I'm not able to set the ip address of the tap device of the vpn server (bridge) permanent.
I use ip addr add 192.168.3.1/24 dev tap_tap, but after reboot of the server the ip address is no longer set.
How could I set the ip address permanently (linux, debian)?
Best regards
Christof
chrisk
Hi Solo,solo wrote: ↑Tue May 17, 2022 12:50 pmSoftEther offers VPN solutions in L2, L3 and SecureNAT mode. To achieve the described objectives in your preferred SecureNAT mode, install a SE client together with SE server on the same PC. The client must not use your vDHCP, set its vNIC to a static IP 192.168.30.2/24 and DG/DNS none.
I changed my setup according to Eddie's comment.
Now I'm using a bridge with tap device and use a static subnet (192.168.3.0/24).
Best regards
Christof
eddiewu
That depends on how you start softether. Put the command in the startup script.
chrisk
Hello Eddir,
I created another systemd service to set the ip address of the tap interface which is dependant on the softether vpn server.service.
First I tried to exec the script with the ExecStartPost directive which didn't work for me.
Best regards
Christof
eddiewu
ExecStartPost should work but you may need to add some delay before setting IP.
chrisk
Hello Eddie,
I use the following script as a service which shows that some time is needed before the tap device is in place.
# cat /usr/libexec/softether/vpnserver/set_ip_tap_device.sh
#!/bin/bash
retval=1
retries=3
while [ $retval -ne 0 ] && [ $retries -gt 0 ]
do
retval=$?
if [ $retval -ne 0 ] ; then
echo "Set tap ip failed, $retval. Retries: $retries"
sleep 2
else
echo "Set tap ip successful, $retval,"
fi
((retries--))
done
Output of systemctl:
# systemctl status softether-set-tap-ip.service
● softether-set-tap-ip.service - SoftEther Set tap IP Address
Loaded: loaded (/lib/systemd/system/softether-set-tap-ip.service; enabled; vendor preset: enabled)
Active: inactive (dead) since Wed 2022-05-18 18:34:20 UTC; 12h ago
Main PID: 901 (code=exited, status=0/SUCCESS)
CPU: 8ms
May 18 18:34:18 systemd[1]: Started SoftEther Set tap IP Address.
May 18 18:34:18 set_ip_tap_device.sh[902]: Cannot find device "tap_tap"
May 18 18:34:18 set_ip_tap_device.sh[901]: Set tap ip failed, 1. Retries: 3
May 18 18:34:20 set_ip_tap_device.sh[901]: Set tap ip successful, 0,
May 18 18:34:20 systemd[1]: softether-set-tap-ip.service: Succeeded.
Have a good day
Christof
