Howto setup my VPN to allow access to the entire remote LAN?
VK6IA
Post by VK6IA » Tue May 24, 2022 9:10 am
Hi Guys,
I am a networking newbie and have a question about my setup.
I'm using Softether VPN server on a VPS running Windows 2016 server. I have a remote PC connected to the VPN via a windows 10 client.
It all works well, however, I can't connect to any of the devices on the remote LAN.
StarLink - Remote LAN 192.168.1.x using Windows 10 softether client
VPS - VPN 192.168.50.x and Internet 180.x.x.x 2016 Softether Server
FTTP - Internet Local LAN 192.168.0.x Windows 10 Softether client
How do I configure the setup so that I can access both LANS from each other? or even the remote LAN from the Local LAN?
Any suggestion would help as this is over my head!
Best Regards
Andrew
Re: Howto setup my VPN to allow access to the entire remote LAN?
Post by solo » Tue May 24, 2022 10:36 am
Hi, the simplest way to accomplish your objectives is with SoftEther Server and Bridges, described here. Specifically...
  • VPS - SoftEther Server, Local Bridge and SecureNAT disabled, Layer 3 Switch enabled
  • StarLink LAN PC - SoftEther Bridge, Local Bridge enabled
  • StarLink router - add static route to FTTP LAN, 192.168.0.0/24 via 192.168.1.254
  • FTTP LAN PC - SoftEther Bridge, Local Bridge enabled
  • FTTP router - add static route to StarLink LAN, 192.168.1.0/24 via 192.168.0.254
