Can VPN Server play also file share host role?
gboymix
Post by gboymix » Thu May 26, 2022 4:55 pm
From the "Remote Access to LAN" use case diagram it looks like that VPN Server has to be a part of the local network.
In my case I don't have a separate machine or device to do that so I wonder can I host SoftEther VPN server on the same windows machine that I plan to use as a file share host?
So basically let my phone and laptop connect to VPN and access files from the same host that is hosting VPN service?
Re: Can VPN Server play also file share host role?
Post by solo » Thu May 26, 2022 10:24 pm
Yes, this SoftEther usage scenario had been extensively explored in Client PC unable to reach shared directory on Server PC.
